dreiing bremsetrommel
T1 - T5 questions, and other topics.
vwbus.no is a Norwegian bus forum. Here in this section we invite questions/comments in English so that people who are struggling with Norwegian can ask questions using English.
Remember! Only English language / Husk! Kun Engelsk!
Forum rules
t3intravel
Car: T3 1983 1,6 D
Post by t3intravel »
Hi!
i'm looking for a garage around oslo where i can do dreiing bremsetrommel
does anyone know it possibile to find in norway?
mvh
Travelle
Re: dreiing bremsetrommel
Post by Travelle »
Hello. I am pretty sure one of theese can help you:
http://www.bremseservice.no/
http://www.brakes.no/v2
Do keep in mind that all kind of labour are very expensive in Norway! Don't be surpriced if new drums is cheaper... :shock:
t3intravel
Car: T3 1983 1,6 D
hi!
its very strange, i change breaks dums by sides, left to rught and oposite. Now it breaks correctly, and before it was going to right during breaking
someone could explein it?
Travelle
Post by Travelle »
If there is a signifficant difference in diameter (wear) between the drums there will, along with the brake shoe adjustment, be a difference in brake effect. If the brake shoes are adjusted close to the drum, most of the friction material will have contact with the drum when the brake is activated. If the shoes are far from the drum, you will have a long brake pedal travel, and only the top of the friction material (closest to the brake cylinder) will have contact with the drum. This will of course result in less brake effect. Read more here:
http://auto.howstuffworks.com/auto-part ... brake1.htm
If your brakes are ok now, I guess you are just lucky :wink:
(ps: The T3 has a self-adjusting mechanism for the brake shoes, but this rarely work after 20+ years...)
