1986 Hightop Westfalia 1,6 TD, byttet motor til AAZ i 2018
Re: 1986 Hightop Westfalia 1,6 TD, bygges om til AAZ i 2018
Hvordan skifte registerreim på en AAZ :D
Ser nå i etterkant at videoen ikke ble helt bra, men det går ann å forstå hvordan fremgangsmåten er.
https://www.youtube.com/watch?v=LDhSMxwZP2c
Fikk delene fra Brickwerks i dag.
Jeg forstår ikke helt hvordan denne skal monteres, så jeg har sendt en mail til de angående dette.
Denne simringen er laget av et annet materiale enn den original (PTFE), konstruksjonen er også annerledes.
https://brickwerks.co.uk/product/crank- ... wheel-end/
Vel, etter litt reseach på nettet, fant jeg denne videoen.
Må visst ha et spesial verktøy for å montere denne ringen.
OBS: Gjelder en annen type ring.
[media]https://www.youtube.com/watch?v=Pkh8_GlQJu4[/media]
Tror jeg fant svaret her 4:15 ute i filmen.
[media]https://www.youtube.com/watch?v=Tzn4OVPSWrU[/media]
Installation of PTFE Oil Seals
TIP FROM THE EXPERTS
Only remove PTFE oil seals from their protective packaging immediately before installation, to protect them from dust and other contamination.
The sealing lip of PTFE oil seals is protected by a plastic sleeve, which can normally be used as an assembly aid.
Therefore, the sleeve should remain in place until the seal has been installed.
If the seal is to be installed without the sleeve, use the special tool provided by the manufacturer.
Both the PTFE sealing lip and the shaft surface must be completely dry. Do not use any grease or oil.
The shaft may not exhibit any sharp-edged chamfers – if necessary, have the edges removed by an engine expert.
The shaft surface must be in a perfect condition – also here, possible damage must be repaired by an expert.
Position the assembly sleeve with the PTFE oil seal on the shaft.
Make sure that the sealing ring is aligned correctly – the sleeve must be located so that the seal can be pushed onto the shaft smoothly.
Push the sealing ring onto the shaft with an even motion.
When replacing, the PTFE lip of the new seal should not run in the same position as the old one.
You can now remove the assembly sleeve.
Do not start the engine sooner than four hours after installation – this permits the new sealing lip to adapt perfectly to the shaft.
When installing integrated oil seals, please note that it is usually necessary to slightly loosen the oil pan to enable the radial seal to be pushed onto the crankshaft.
Damaged PTFE Sealing Lip
The most frequent cause for failure is damage to the PTFE sealing lip during assembly.
If the seal is installed without the help of a sleeve or special tool, and is shifted or even turned inside out, reliable sealing will hardly be possible.
Similarly, the use of oil or grease – as with classical oil sealing rings – will result in total failure of the PTFE oil seal immediately after installation.
Virker litt unødvendig vanskelig, jeg byttet bare ringen uten at det har gitt meg noen problemer. Du trenger forøvrig ikke noe spesialverktøy, det hvite plast senteret utgjør dette verktøyet. Gudd løkk. :wink:
Needforspace wrote:Virker litt unødvendig vanskelig, jeg byttet bare ringen uten at det har gitt meg noen problemer. Du trenger forøvrig ikke noe spesialverktøy, det hvite plast senteret utgjør dette verktøyet. Gudd løkk. :wink:
Jo takk, gudd løkk kan jeg vel trenge her :D
Ser i video nr2 at han bare presser ringen på plass og den hvite plastringen faller ut av seg selv.
Fant feilen som forårsaket oljelekkasjen :o
Rart jeg ikke merket dette når jeg monterte den!
Ny simring montert, og lekkasjen er nå borte :D
Byttet noe gummigreier ved girkassen i dag.
https://www.youtube.com/watch?v=FssYLKW ... e=youtu.be
Da var endelig riktig størrelse Dieselvarmer kommet i hus.
Samme tollbehandling som den første jeg fikk :lol:
Sammenligningsfilm mellom 2kw og 5kw.
[youtube]https://www.youtube.com/watch?v=mivEyt3BwTc[/youtube]
[media][/media]
Westfalia edition :D
Ble langt ifra bra, men bra nok
Snubblet over denne i dag :D
Byttet den til meg mot 2 brett med Colabokser 8)
Det morsomme er at denne fra Kina er oppgitt til 1500 watt og den store (og tunge) fra Victron bare er 800 watt.
Den fra Kina er riktig nok en Modify sine wave, og den fra Victron er en Pure sine wave :D
"W" utgang laget på min 120 ampers dynamo.
Om jeg får den til å passe i bilen er en annen sak.
NB: Pass på at du lodder deg innpå en vikling og ikke en diode!
Dioder gjenkjennes igjen på at de er runde og presset inn i huset.
Monterte mine flott beauty ringer fra http://www.brickwerks.co.uk i dag.
Synes selv de ser riktig så flotte ut :D
[youtube]https://www.youtube.com/watch?v=OWjvhJS-Wqs&t[/youtube]
Ny gassalarm :D
Re: 1986 Hightop Westfalia 1,6 TD, byttet motor til AAZ i 20
I dag fikk jeg endelig startet på lydoppsettet mitt.
Nede på døren kan en se det gamle hullet fra de små 4" Pioneer høyttalerne som stod der da jeg kjøpte bilen.
Brukte litt tape for å forme plasten som en kule over høyttalerne. Da skulle de tåle en regnskur eller to.
Hvor mye har du igjen av nyttelasten nå da?
Buss Marius wrote:Hvor mye har du igjen av nyttelasten nå da?
Tja ikke godt å si, men har en god følelse så langt :D
Byttet girolje til Biltema sin mineral olje 80W-90 LS, og virkningen kom umiddelbart.
Ingen skraping i 2.gear lengre, girene er helt synkrone noe de ikke var med den syntetiske oljen. :D
Så da er det vel noe i dette at syntetisk olje blir for glatt til at synkronringene får tak.
Tekniskedata på AAS girkasse (og andre typer)
Fikk koblet til styringspinne på tenningslås, slik at radio slår seg på når en setter nøkkel inni tenningslås (trenger ikke å vri nøkkel rundt)
Tenningspinnen styrer et rele slik at radio blir drevet av batteriet under setet.
https://www.youtube.com/watch?v=C5MeILjfAvc
Mine nye kjøkkenvindu og luftevindu venstre bak samt ventil til skyvedør og vinduer fremme.
Ikke fått montert vinduene enda, men det er ikke lenge til nå :D
Kjøpt hos http://www.serial-kombi.com
Jeg har aldri kjøpt noe fra Serial-Combi. er de kjappe å ha med å gjøre? Hva kostet vinduene, med forsendelse?
De har en fantastisk service. Jeg fikk mine sendt til mitt hotell i Tyskland, og klarte å "snakke" til meg gratis frakt.
Philipp er mannen jeg hadde mailkontakt med der nede. Fikk tracking sendt på mail og alt var bare fryd og gammen.
Litt tungvindt betaling, da jeg måtte overføre pengene i nettbanken.
Venstre skyvevind (lang versjon1080x428mm) Reference 253847711
https://www.serial-kombi.com/en-GB/tran ... 92-n316557
Høyre skyvevindu bak Reference 253847766
https://www.serial-kombi.com/en-GB/tran ... 41-n317979
Bilde fra Serial-kombi.
Soting av vinduer :D
Brukte Biltema sin varmeavvisende solfilm Art.nr. 39-776
Tekst fra Biltema:
Varmeavvisende solfilm som reflekterer bort opptil 80 % av varmen fra solen og avviser skadelig UV-stråling.
Holder bilen kjølig om sommeren og varm om vinteren.
Runner
Car: T3 1989 JX
Phone: 9+7-7-2-2-2-1+2
Post by Runner »
Litt vel sært å bytte ut vinduer på huset med T3 vinduer, men jeg forstår deg. Blir bra!
Runner wrote:Litt vel sært å bytte ut vinduer på huset med T3 vinduer, men jeg forstår deg. Blir bra!
[emoji23][emoji23][emoji23][emoji23]
Sent fra min H9436 via Tapatalk
Kjøpt meg en Sharan :D
AFN 1,9 110hp
