Stemmer det, på enkelte dempere kan du justere både kompresjonen og rebounden
trailmaster er presatt og kan ikke justeres men du kan velge noen forskjellige varianter
(saksetr fra
http://www.syncro-services.com/en/suspe ... -a-springs)
The rear shocks "comfort" have been developed according to our specifications
(original length: 364/590mm, Trialmaster "comfort": 398/638mm),
the shock allows approx. 5cm more wheel travel, ideal for higher Syncros
(springs / rear axles has to be at least 20mm higher than original when using these shocks).
Result: comfortable and longest wheel travel, top for offroading, our best seller!
The rear shocks "sport" are approx. 20% stiffer inward and 15% stiffer outward direction than "comfort",
also useful for higher Syncros (original shocks: 364/590mm, Trialmaster "sport": 385/613mm),
this shocks provides approx. 2.5 cm more wheel travel, ideal for heavy Syncros and expeditions!
Hvis den går for "fort" tilbake så har du for hard modell og/eller for korte dempere i forhold til hvor mye du hevet bilen
