kjøleveske mistet farge
Kjører normalt med rød kjøleveske, men merket her en dag at den var blank som om det bare var vann på tanken. Kan denne miste farge og har den fortsatt noen smøreefekt og at den ikke fryser i minusgrader?
Re: kjøleveske mistet farge
http://forums.vwvortex.com/showthread.p ... r-winter#7G12 is very prone to cross-contamination with other coolants initially... so a very very thorough flush is required. And, if you install it and it doesn't stay a bright pink some old stuff was still left behind... drain it and start again.
