Bilen ble ferdigstillt 27. april og fikk sine skilt 23. juni 2000. To'ish måneder gammal, altså.
1 0AB L STV front stabilizer
2 0BA L STH without rear stabilizer
3 0CN I AED vehicle class differentiation 7D0
4 0D1 L TFA cab doors
5 0E1 I RST short wheelbase
6 0FA L FAD standard manufacturing sequence
7 0G1 L GES gearshift lever
8 0J2 L NUL standard payload
9 0KA L KAE without stickers and badges
10 0QW L SZU nameplate set in base trim with black guide rail (without model designation)
11 0SQ L SAU labels/plates in Norwegian
12 0Y3 L KLZ cold zones
13 0ZN L AUE transmission ratio, high geared
14 1AD E BRS anti-lock brake system (ABS) with electronic differential lock (EDL)
15 1B6 L REH swiveling spare wheel bracket at rear
16 1BA L DAE standard suspension/shock absorption
17 1C2 L FRO antifreeze up to -35 degree celsius tolerance up to -40 degree C
18 1D0 L AHV without towing attachment
19 1E0 L AKB without activated charcoal canister
20 1EX L TYP special identification plate for EC
21 1G2 L RER steel spare wheel with original equipment tires
22 1J2 L LSD sound deadening package and additional enclosures for some units
23 1K3 L KUB hydraulic clutch actuation with over-center spring
24 1L0 L LUF standard air cleaner
25 1LU L BAV disc brakes, front
26 1ND L RAA full wheel covers
27 1P0 L FFW standard suspension
28 1S1 L BOW tool kit and jack
29 1SA L TWU without additional engine guard
30 1U0 L KLT without table
31 1W0 L KBX without refrigerator/glove compartment cooling system
32 1X1 L ATA four wheel drive
33 1Y0 L DIF without differential lock
34 1Z3 L KRM double initial standard fuel filling
35 2A0 L UEA without delivery equipment
36 2BA L HYP without hydraulic pump
37 2E2 L FAW 15-inch chassis
38 2G0 L EBB without insert for the filling up of fuel
39 2JB L STF standard bumpers
40 2N1 L ETD standard anti-drum measures
41 2PG L LRA steering wheel
42 2WA L ZBR without additional tires
43 2AA L KMK without compressor or preparation respectively
44 3B0 L ZKV without additional child seat anchor
45 3CA L TRW without partition
46 3E0 L SPW w/o stacking panel in load compartment
47 3EA L DFA without roof insert in cab (closed)
48 3HA L LTU without leather parts scope
49 3J1 L KOV height-adjustable headrests for front seats
50 3JA L DFL without roof insert in load and passenger compartment
51 3LQ L TSV door trim panel
52 3P0 L HAL without bracket for first aid kit and warning triangle
53 3Q1 L KOH rear headrests
54 3QC L RSV 3-point seat belts, front
55 3R3 L DAA pop-up roof
56 3RC L HET trunk lid with window aperture
57 3SD L SFR swivel seat in cab, right
58 3TD L SFL swivel seat in cab, left
59 3UA L ESR without seats
60 3VA L ZSR without seats in second row of seats in passenger compartment
61 3W6 L GDM additional interior noise suppression
62 3WA L DSR without bench seat
63 3YB L TAV door pockets, front
64 3Z0 L AKS without side panel pocket
65 4A3 P SIH seat heater for front seats separately controlled
66 4CB L FFH Cab side window in clear glass
67 4DT L VSL quarter vent tinted (acrylic glass) in load/passenger compartment front left
68 4E3 L SDH without tailgate release lever inside
69 4ER L VSR side window double glazing load/passenger compartment front right
70 4FG L HSL side window double glazing in load/passenger compartment rear left
71 4G0 L SVK w/o storage trays, first row of seats
72 4GS L WSS Clear glass windshield, bonded
73 4H2 L KDS child lock for sliding doors in passenger compartment
74 4HL L HFE rear window double glazing
75 4JG L HSR side window double glazing in load/passenger compartment rear right
76 4K1 P TKV radio remote controlled central locking
77 4M1 L BEH cup holder in cab
78 4N1 L INT padded dashboard
79 4PA L SEF without seat belts in first row of seats
80 4R1 P FEH power windows
81 4RA L SZS without seat belts second row of seats
82 4S1 L ALV armrests for both front seats
83 4SA L MSL without left vanity mirror
84 4TD L MSR right vanity mirror illuminated
85 4UE L AIB airbag f. driver a. front seat passenger
86 4VA L SDS without seat belts in third row of seats
87 4WA L SHK w/o storage trays, second row of seats
88 5AD L BFH carpet floor covering in cab
89 5BA L BFL without floor covering in passenger/loadcompartment
90 5CA L DIV without roof interior trim
91 5D1 P TRF carrier frequency 433.92 MHz
92 5DH L SIV side panel trim for Camper living compartment
93 5EA L AFZ without different vehicle equipment
94 5FE L ALF tray under dashboard, center
95 5G0 L GAD without curtains
96 5GA L VGP without top frame and tarpaulin
97 5HA L PBR without pickup bodywork
98 5JA L BTK Without ambulance seat for medical staff
99 5K0 L LAC without paint preservative
100 5LA L KRT Without stretcher
101 5M0 L WSU without warning strip and films
102 5NC L FHE standard tailgate stay
103 5P0 L AFS w/o mounting fixture for oxygen bottle
104 5PA L KTS Without invalid chair
105 5Q0 L TLL without door in load/passenger compartment left (closed side panel)
106 5R2 L TLR sliding door right in load/passenger compartment
107 5RQ L ASR outer right rear view mirror: convex
108 5S0 L BWK without tail and side gate(s)
109 5SL L ASL outer left rear view mirror: non-spherical
110 5T0 L HBK without retaining cables for tailgate
111 5U0 L UBS standard underseal
112 5V0 L SBH without hinges for side and tail gates
113 5Y1 L HKB additional heating/air conditioning actuation in passenger compartment
114 6AC L ZWT second heat exchanger
115 6B0 L VZU without tie-down eyes for load restraint
116 6FA L BBO components without special surface appearance
117 6K0 L SBV without lock washers for padlock
118 6L0 L CHS without C-rails
119 6LD L FLA fresh air unit with center outlet and recirculation door, without load/ passenger compartment ventilation
120 6N0 L SZF without mud flaps
121 6U0 L ZTD without additional seals outside
122 6XD P ASE outer rear view mirrors: powered, heated
123 7B0 L STD without socket
124 7J0 L ZEL without additional ventilation system
125 7Q0 L NAV without navigation device
126 7QA L CDR without CD ROM
127 7VH P ZUH auxiliary and parking heater, timer and temperature control in central control unit
128 7AA L EDW electronic vehicle immobilization device
129 8BB L HSW halogen headlight for driving on the right
130 8CC L TWP speedometer sensor without seal (electronic speedometer sensor)
131 8E0 L ENT without interference suppression
132 8FA L ZBA without second battery
133 8G0 L ZAL without antenna cable for radio system
134 8GL P GEN alternator 120A
135 8HA L ZGE without second alternator or preparation
136 8K1 L FLS daytime running lights mode
137 8L8 L ANT inside-windshield antenna
138 8M1 L HEW rear window wiper and washer system with intermittent control
139 8Q1 L LWR headlight-range adjustment
140 8R1 L HBL center high-mounted stop light
141 8RH L LSE four loudspeakers (passive)
142 8T0 L GRA without cruise control system (CCS)
143 8TC L NEL rear fog light for driving on the right
144 8WA L NES without front fog light
145 8X0 L SWR without headlight washer system
146 8Y1 L SNH two-tone horn
147 8AA L RAO without radio
148 9AB P HKA manually controlled air conditioning
149 9CA L ILE without interior light in passenger/loadcompartment
150 9GA L ASI interior light with door pillar switches
151 9H0 L DBL without roof turn signal lights
152 9HA L FFA without additional malfunction display
153 9J0 L STA without supertone system and tone sequence control
154 9KA L EKL without identification lights
155 9LA L RTK without rotating emergency lights
156 9N2 L TSB step illumination with on/off control
157 9NA L FAS without tachograph
158 9P0 L SGK without seat belt warning light
159 9Q0 L MFA without multi-function indicator/ on-board computer
160 9QA L VEL without identification light preparation
161 9T1 P BWD heated washer nozzles, front
162 9W0 L VTV w/o car phone preparation/installation
163 A8L I AUS Camper equipment
164 AC1 L VDW long frame forestructure
165 B06 L TPL type approval Norway
166 B0P L BLB component parts set, complying with vehicle type for Norway, various parts
167 C02 E COC operating permit, alteration 2
168 C7X L RAD steel wheels 6J x 15 H2 load rating 810kg, offset 55
169 E0A L AAU no special edition
170 F0A L FZS no special purpose vehicle, standard equipment
171 FM6 L MDS California "Coach" variant
172 G0G I GSP five-speed manual transmission for four-wheel drive vehicle
173 H6W L REI tires 205/65 R 15 C 100T
174 J1U L BAT battery 450 A (95 Ah)
175 K4C I KAR bus
176 L0L L LEA left-hand drive vehicle
177 M9M I MOT 5-cyl. diesel engine 2.5 L/75 kW TDI distr. inj. pump, turboch., interc., EGRbase engine is T7K/T8S
178 N3D L SIB fabric seat covering "Step by Step"
179 QG1 L WIV service interval prolongation
180 T7K I GMO 5-cylinder diesel engine 2.5 L unit 074.5
181 U0C L INS instrument insert with tachometer clock and km/h speedometer
182 V0A L REL tires w/o specification of tire brand
183 X1C G Landessetzung Norwegen
184 ZE1 G "Locking & Unlocking"
185 ZK1 G manually controlled air conditioning
186 ZW3 G winter package 3 (parking heater)
-Makan til effektiv utbrodering av prosjekttråd tror jeg ikke jeg har sett noe sted før, forresten
Hva lista over PR-koder angår så er det etpar momenter for mange der og etpar (pluss) for lite ift hva som er på bilen pr idag.
Den har vært eid av et firma de første årene, som ei uke etter registrering fikk ettermontert hengerfeste. Ett år etter var bremseklossene bak bytta. Mai 2003 reparasjoner etter tyveriskade, og bilen fikk bl.a alarm.
Rett etter kjøpte han jeg kjøpte av bilen, og han bytta bakruta - jeg mener å huske det ble nevnt at Langfinger-Lars tok seg inn den veien så da så.
Januar 2004 reparasjon av skade i front, mener å huske mindre kollisjonsskade ble nevnt
August 2004 LMM bytta.
Feb/mars 2009 ny kollisjonsskade, og desember 2011 "tatt ut satt inn" reg.kjedet
"Bytta" hadde holdt lenge for å gi meg ro i sjela men det er PKK i oktober i år så vi skal vel få årna ting om det ikke er utført enda
Yepsi, pepsi. Det kommer interiørbilder som Peter etterlyste om ikke så lenge, eks-Svigerfarmin har hatt havari på sin snart veteran-MB så han skrota den (isf å betale 25k i nødreparasjoner) og hans 2009-MB stv familiebil trenger også 25k for å bli kjørbar igjen. Siden jeg fremdeles bare kan kjøre ett kjøretøy i slengen låner de Multivanen mens jeg koser meg med den nye bilen.
Hehe, kanskje jeg skulle la dem kjøpe den for en grei pris ? Tja, da skal de jaggu få en godt pristilbud å strekke seg med letthet etter også, da. Får godsnakke med dem etter at de har kjørt den noen uker
EDIT - på tross av factory spec over har den EDS på bakakslinga også, det er "for mye krimskrams" på bakakslinga til at det bare er EDS på framakslinga. Bakaksling uten sperre er "flat" bakpå klokka der, mens denna har diverse utbulinger (støpt før montering, takk) og dermed er det jaggu electrisches differential schperr. -Så da så.
