How to fight rust i "skjøtene"
jayster
Post by jayster »
i am just wondering how i can overcome the rust in nearly all the skjøtene,can i sand them down and paint with some kind of anti-rust paint then spray on the top layers of paint???
ThorAlex.
Post by ThorAlex. »
to do it right you have to scrape out all the filler, sand down the rust and then apply new filler and paint.
xavi
Car: ´87 Caravelle C 2.1 L 8 seater
Post by xavi »
To get a long lasting result, sand blast the joints, weld them with tin, prime them,and lastly paint them. You will even not see the joints. I have done this with one of the joints years back and I can see no sign of rust with that joint. The operation might be exspensive. Might ned a proffessional.
Tæff
Post by Tæff »
Also i have heard that the rust is coming from the inside. So you need to get to the joint from inside the car and sandblast it and put in some kind of primer. Then you need to do the same at the outside.
This is the resepe I was told to follow for a lasting result.
Siste år:
95 modell Vw transporter...
jayster
Post by jayster »
Ok thanx for the replys!
