Kjørt 180 km i timen!
jayster
Post by jayster »
Jaja kansje ikke helt da,men spedometer sier sann!
etter at eg byttet instrument panel er spedometer helt hvilt,det virker sann at det leser dobbelt den farten eg kjøre,ka kan dette være tror dere??takk jayster :D
2wd speedometer i en syncro blir sånn...
jayster
Post by jayster »
OddN wrote:2wd speedometer i en syncro blir sånn...
shit da ma vi bytte den ut igein da jaja man lærer så lenge vi lever :D
Car: DJ, JX 2wd og Syncro
Phone: 911 to-seks 8-ni-5
Post by Bugman »
Skru over ditt syncro speedometer så ordner det seg..
(Hvis det ikke er ødelagt da...)
Det skal stå 1000 nederst i ett speedometer for syncro...
jayster
Post by jayster »
Bugman wrote:Skru over ditt syncro speedometer så ordner det seg..
Hva mener du skru over over bytte spedometer?
Post by Bugman »
You've changed the instrument-panel, right??
If you look on these panels, you'll se from left-to right:
- Speedometer
- A cluster of warning-lights (oil, charge etc.) (And maybe a digital Clock if you have a rev. counter.)
- Either a analog clock or a Rev counter.
If you flip the panel over, you'll se four phillips-screws that holds the "pot" containing the speedo.
Unscrew those, carefully pull out the (supposedly) 2wd Speedo and put in your syncro speedo, reverse order.
If YOUR syncro speedo is broken, you'll only need a speedo from a syncro, not the whole panel.
Hope this makes more sense.
