ENDELIG en skikkelig røff 4x4-versjon av transporter!!
avdem
Car: T3 1990 syncro mTDI
Phone: 48232026
Transporter Rockton
Post by avdem »
Flere som har fått med seg denne?
Transporter Rockton, T5 allmotion med bedre offroad egenskaper. Er det bare et nytt navn på offroad utgaven eller noe helt annet?
http://busman.be/pagina40aa.html
Halvard Avdem
avdem
Phone: 48232026
Re: Transporter Rockton
Post by avdem »
http://www.volkswagen-commercial-vehicl ... traum.html
Der var den gitt, ser ut som om de har oppgradert offroad versjonen litt, fin bil......
Halvard Avdem
Hurra :D Dette ser jo smågromt ut.
Kommer denne til Nårrge da?
Re: ENDELIG en skikkelig røff 4x4-versjon av transporter!!
http://vwphaetonfan.blogspot.com/2010/1 ... sters.html
The Rockton is based on the Transporter Kombi, but by virtue of its standard 4-wheel drive has more grip on unmade roads. The permanent 4MOTION four-wheel drive with a 4th generation Haldex clutch, a differential lock as standard on the rear axle, height raised by 30 millimetres and strengthened suspension and shock absorbers (3.2-ton chassis) enable the vehicle to take its passengers and cargo reliably through almost impassable terrain. The Rockton even takes gradients of up to 36 degrees comfortably in its stride.
For extreme off-road use there’s the ‘Expedition Pack’, which makes the Transporter Rockton ready to set off on any great adventure. Noticeable externally are the 16-inch AT tyres on strengthened steel wheels. The main changes, however, come in the detail: a particular feature of this version is a special gearbox that provides increased traction in off-road mode. And even though the Rockton has been tailored to the special conditions of off-road motoring, it is fully suited to road use as well. For use away from made-up roads undercarriage protection elements shield the engine, gearbox, tank, sills, rear-axle differential and main exhaust silencer.
Den begynner ta form, om ikke annet. Godt potensiale og ikke minst - en platform hvor et godt grunnlag er lagt slik at transformasjon til en ånkli bil er lettere.
Så også en T5b DOKA der med 4mosjon, kunne vært noe :wink:
-Om den kommer hit ?
Mye penger har du på deg ? De tar vel inn alt kunden maser nok om, selv om svaret sikkert vil være "nei" en tid :lol:
Noen som har hørt noe konkret om denne modellen og evt offisiell import til bakvendtlandet?
Thunder
Car: T5 Transporter 2005
Post by Thunder »
Den der hadde vært helt sjef! Men den blir vel som med alt annet i dette landet, altfor dyr.
avdem
Phone: 48232026
Post by avdem »
Halvard Avdem
Jeg skulle slå ihjel litt tid i forrige uke. Etter som jeg har det meste av brosjyrer av T3 og T4 som er utgitt fra 83 til 2000 men ikke en neste T5 tok jeg turen innom Auto E18 for å samle det som var av T5 brosjyrer. I Multivan brosjyren var det avbildet en med dekor: PanAmericana. Dette ser ut til å være en variant av Rockton. Noen som vet noe om denne/disse?
http://www.google.no/search?q=vw+paname ... 50&bih=562
Om du hadde funnet og kunnet bruke søkefunksjonen ville du sett at PanAmericana er nevnt etpar ganger her :D
Det er en annen versjon enn Rockton (høres litt Ssangyoung ut, gjør det ikke ??) :wink:
EDIT - slang på etpar smiletryner så det ikke skal virke som om jeg sitter og er sur fordi jeg ikke er våken enda :D
Hva sier prislista om Rockton og PanAmericana (som aldri kom) forresten ?
