Temperature switch or sensor
xavi
Car: ´87 Caravelle C 2.1 L 8 seater
Post by xavi »
Guys,
Need help. Temperature needle won´t budge from it´s normal position.
Where do I locate the switch or the sensor? How difficult is the job?
I tried to find answer in previous threads but couldn´t find it.
VW BUSS. 2.1L. 1987.
Thanks.
Xavi :)
Re: Temperature switch or sensor
you find it on the thermostate house on the side pointing forward.
easy to change, rize the left back of the car. Have the new one in stand by, pull out the sprint on the sensor and pull it out and replace it with the new one. Refill with water and empety the system from air.
xavi
Post by xavi »
Thank you mate for the diagram and a quick reply.
I appreciate it. I will try to change it coming week.
I will drop a word about how it goes?
Xavi
before you change the sensor/sender check it with a ohm meter, if it doesent indicate a brake than are the sender proberly ok, you can check from the connections on the digijet box,
download this and read
https://docs.google.com/open?id=0B0UCQ0 ... MwMDE5NTY4
xavi
Post by xavi »
I have changed the sensor located on the thermostat house but still no reaction.
The temperature needle won´t move. Is there a second sensor?
What is the next step?
If you connect the cable to earth then should the sensor indicate max temp if not then.it's a trouble with the cable from the.sensor to.the.instrument
Sent from my C6903 using Tapatalk
Tistlo
Car: plenty
Phone: 97419035
Post by Tistlo »
on some of mine cars, trouble with instrumens have accured at the multipin thing on the back of the instrument cluster. remove it, clean it and try again
- 97419035 -
T3 luftkjølt x3
T3 2wd x1
T3 syncro pickup x5
T3 syncro x6
T3 syncro 16" x2
+luftkjølt ukjent mengd.
entusiasme>sunn fornuft
xavi
Post by xavi »
Thanks for the tips Guys. I will try out tomorrow in day light.
xavi
Post by xavi »
Pardon my ignorance. May you please expand on which cable to connect to the earth.
