Valg av hjullager og evt andre deler.
Didrik
- Car: 2016 Transporter 2,0 tdi 4-motion
- Phone: 92081718
Hei!!!
Sitter og lurer på hvilket merke jeg skal velge av hjullager og evt hvor jeg skal kjøpe det.
En liten sjekk på nettet ga meg noen få valg:
Analogous \ Similar Parts of VOLKSWAGEN 7D0 498 625
Manufacturer Number Description
A.B.S 200055 Wheel Bearing Kit
AUDI 7D0 498 625 Wheel Bearing Kit
AUTEX 802039 Wheel Bearing Kit
AUTOMEGA 3049806257D0 Wheel Bearing Kit
AUTOTEAM RA1034 Wheel Bearing Kit
AUTOTEAM RA1030 Wheel Bearing Kit
BENDIX 050759B Wheel Bearing Kit
BREDA LORETT CR 2226 Wheel Bearing Kit
CALIBER RC1034 Wheel Bearing Kit
CALIBER RC1030 Wheel Bearing Kit
FAG 713 6103 40 Wheel Bearing Kit
FEBI 19914 Wheel Bearing Kit
FIRST LINE FBK701 Wheel Bearing Kit
FLENNOR FR190198 Wheel Bearing Kit
FLENNOR FR199195 Wheel Bearing Kit
IPD 30-1034 Wheel Bearing Kit
JP GROUP 498355001ALT Wheel Bearing Kit
KAGER 83-0350 Wheel Bearing Kit
KAWE FR190198 Wheel Bearing Kit
KAWE 12328 Wheel Bearing Kit
KAWE FR199195 Wheel Bearing Kit
KM INTERNATIONAL RK1034 Wheel Bearing Kit
KM INTERNATIONAL RK1030 Wheel Bearing Kit
LUCAS ENGINE DRIVE LKBA60011 Wheel Bearing Kit
MAGNETI MARELLI 361111183228 Wheel Bearing Kit
MAPCO 26708 Wheel Bearing Kit
MASTER-SPORT 3406-SET-MS Wheel Bearing Kit
METZGER WM 997 Wheel Bearing Kit
MEYLE 100 498 0219 Wheel Bearing Kit
MGA KR3484 Wheel Bearing Kit
MOOG 510051B1 Wheel Bearing
NK 754727 Wheel Bearing Kit
OE 1004980219 Wheel Bearing Kit
OE 7D0498625 Wheel Bearing Kit
OPTIMAL 101209 Wheel Bearing Kit
PEX 16.0555 Wheel Bearing Kit
QUINTON HAZELL QWB997 Wheel Bearing Kit
RENAULT 7D0498625 Wheel Bearing Kit
RPK RPK13406 Wheel Bearing Kit
RUVILLE 4097 Wheel Bearing Kit
SBS 1401754727 Wheel Bearing Kit
SCT GERMANY SCP 3406 Wheel Bearing Kit
SEAT 7D0498625 Wheel Bearing Kit
SK SK13406 Wheel Bearing Kit
SKODA 7D0498625 Wheel Bearing Kit
SNR R140.97 Wheel Bearing Kit
SPIDAN 27166 Wheel Bearing Kit
SWAG 30 91 9914 Wheel Bearing Kit
VAG 7D0498625ALT Wheel Bearing Kit
VAG 7D0498625 Wheel Bearing Kit
VAICO V10-0041 Wheel Bearing Kit
Jeg er fullstendig klar over at flere av disse settene skiller på pakker for foran og bak. Og at lageret foran og bak er likt
Er alle delene som er for pakker for bytte av fremre hjullager nødvendig å bytte? Eller holder det med lager og låsering?
Noen mener at denne jobben bør gjøres av profesjonelle. Andre mener at alt som kan gjøres selv skal prøves og det kan gjerne brukes de billigste deler.
Jeg er nå ute etter å finne et hjullager eller en pakke til bruk foran. Av best mulig kvalitet til rimeligst mulig kostnad.
Vurderer nå å kjøpe et lager av fabrikat OPTIMAL fra skruvat.no
Selve jobben trenger ikke diskuteres i denne tråden. Det er gjort før. Og den er ganske grei skuring.
Før i tida var det liksom mye enklere. Da var det en lokalt som kunne levere noe billigere deler enn på VW sjappa. Og han hadde ikke mange valg selv heller.
Her er det også mulig å diskutere kjøp av andre deler. Se emnet i tråden.
Re: Valg av hjullager og evt andre deler.
best kvalitet og rimelig er strengt tatt to ting som ikke henger sammen.
Kjøp enten SKF lager eller originalt.
- Phone: 917 97 848
Kvalitet pr krone så stiller originalt meget sterkt. Skf som nevnt er også solid.
En kollega kjøpte en gang et Mekonomen lager, for å sammenligne. Dette ble så delt i 2, og gjett hva? Færre kuler og de var mindre i diameter. Ikke rart dette lageret var billigere. Holdbart? Tvilsomt. Vet ikke om de har samme produsent av lager per i dag, men verdt å tenke på.
dewalter
- Car: T4 2000 TDi og 1992 2,5 B
Unngå falske SKF lagre, - kjøp hos en annerkjent forhandler!
Forfalskninger oppdaget:
http://www.skf.com/no/news-and-media/ne ... ction.html
T4 -00 Caravelle 2,5 TDi
T4 -92 Caravelle 2,5GL (Bensin)
T3 -82 1,6 Diesel Reimo camper
california
Og kjøp for guds skyld ikke Biltema!!!
På V70'en holdt de i ca 5 mnd før hjulene romlet som gale igjen.
SKF eller orginalt er tingen. Jeg kjøpte SKF.
XC70 D5 2004 - konas bil.
- Phone: 917 97 848
Sjokkerendecalifornia wrote:Og kjøp for guds skyld ikke Biltema!!!
Didrik
- Phone: 92081718
Hvem leverer SKF lagre raskt og rimelig?
Didrik
- Phone: 92081718
Fikk SKF lager for 750,- hos Bilutstyr på Notodden.
Didrik
- Phone: 92081718
Finnes prisliste på orginaldeler tilgjengelig på nettet?
de må du nok henvende deg hos VW for å få. Noe jeg forøvrig ville gjort først uansett. Det er ofte nå idag at du blir overrasket over prisene i positiv retning.
- Phone: 917 97 848
ca 1200,-før evt rabatt med alt du trenger for skifte med låsering, muttre, bolter osv.
Didrik
- Phone: 92081718
Sitter og lurer på å kjøpe endeledd på nett. Mye å velge i.
Finner denne, som jeg satt på bilen sist og som har gitt meg trøbbel. Kan noen, ut i fra spesifikasjonen, fortelle meg om denne er rett til en 99 mod.
Innvendig gjenge [mm]:M16 x 1,50 RHT F
Konusmål [mm]:12,75
Monteringsside:framaksel
Monteringsside:høyre
Monnteringsside:ytre
Vekt [kg]:0,4
Yttergjenge [mm]:M12 x 1,50 RHT M
Konusmål [mm]:12,75
Vekt [kg]:0,4
Tja.. eg kjøpte lager av Meka. Har vel rulla 150.000km etterpå og fungerer fortsatt heilt fint. Det orginalmonterte holdt ikkje så langt.
