Hi guys,
I'm from Germany and have got a Volkswagen T3 Westfalia. The engine was changed last year. Its now a 1,9l Turbo Diesel from a Golf 3. Now it ran about 204000km.
Last week I wanted a VW garage to do an oil and oilfilter change but the whole thread of the screw broke down. I did some research and it seems like this is not a very rare thing that happens to these cars.
So I need a garage or private person who can set in a bushing, to stop the cars' leaking. Maybe you can or you know a person that can make that?
I'm now for 1½ weeks more in Oslo. After that I'll travel to a city near Trondheim.
This car is my home, I live in it, that's why the repairing should be done in one day.
I really appreciate your help! Thank you in advance!
Lina
T3 Westfalia leaks of oil after oilchange
Re: T3 Westfalia leaks of oil after oilchange
If its the drain screw leaking, this kit has all you need to fix it in less than a half hour:
http://www.biltema.no/no/Bil---MC/Verkt ... gg-191351/
You need the M15-1,5 kit.
Drain the oil, tap new threds, pour some oil trough to clean out the hole.
Put new plug with copper ring, and refill 4l oil.
This is easy enaugh to do yourself...
Tusen Takk for hjelp!!
jokgel
- Phone: 004915904504925
Da ha jeg snakkke med hu lina og det skal fikses I morgen hos meg! Ha hvert hos ei VW verksted til og skifte olje, da var tappeplukgjenging ødelagt og det blir limt...
hilsen jørg
Flott. Hadde satt pris på sånn hjelpsomhet selv jeg om jeg var på tur i annet land.
jokgel
Og så hadde broder mi et sett med nye plukk liggene. Følger ja med 6 stk. I eske ifra tema.Ingen store sak dette !
hilsen jørg
Spesielt at verkstedet ikke ordner opp selv, det burde da vere en smal sak å gjøre...
jokgel
Da har hvert hu Lina hos meg klokka 19.00 og kunne ta af tomter 21.00 ! Etter at Niels min bror ha banka bort epoxilim
som var rund det hele kunne vi tappa olje og kjike lit næmere hvorfor det ha lekker ved pluggen. Gjenging se helt strøken ut, og flensen også. Kopperpakning var på plass. Joda,
den ha brukt helikoll gjengerepsett og vis en borer op til denne størrelse at du få in ny gjenging so dekke ikke den gamle plugg hele oplagsflensen med pakning. Brukte ei pakning ifra hydraulik med vulkanisert gummi invendig. Bilen kommer tilgake I helgen til og skjekker om den holde seg tett nå. I tilleg tilverker vi en nye tappeplukk at vi dreie ned en hjulbolt fra t2, ern at den koniske del blir flat, da blir det ei stort nok opplagsflate til og avdekker hele pakningsflate ti bondpanna. Gjenging er ja de samme som hjulbolt
hilsen jørg
-Send regning til "verkstedet". Mitt eneste tips i saken.
